Seems like not getting fuel gave it shot of starter fluid it ran normal briefly then died
Monday, August 2nd, 2010 AT 3:02 AM
BLUELIGHTNIN6
MECHANIC
Can you hear fuel pump prime up when first turning key in ignition?
SPONSORED LINKS
Monday, August 2nd, 2010 AT 3:27 AM
PAWNSEVEN7
MEMBER
1 POST
Never ever herd the fuel pump prime in this car before must have been real quiet. Is there another way to tell
Monday, August 2nd, 2010 AT 12:42 PM
BLUELIGHTNIN6
MECHANIC
Will need to use a fuel pressure gauge to test for fuel pressure. If there is no pressure than fuel pump is most likely at fault. If there is pressure but its low then the fuel filter may be clogged.
