Windshield wipers are not working
IMPALASS
  • 3,112 POSTS
To better support you is your model just the Cavalier or the LS or LS Sport. Also, what is you engine size in liter? Last, while I am starting to look up the information is your lights and wipers on the same switch?
Tuesday, December 27th, 2016 AT 6:12 PM (Merged)
GGROCCO43
Regular model, four cylinder, changed fuses, dealer took out steering column could not find anything. Lights and wipers are on different switches.
IMPALASS
  • 3,112 POSTS
Thanks for the information.
First check all the wiring by and under the battery tray. You are looking for corrosion and bad connections. These must be clean and good contact. There is a splice number SP102 that is under the battery tray. Both the wiper and headlights go to this. Remove the battery and tray and as I said look really good peel some of the insulation back it you have to. To clean all battery corrosion use Arm&Hammer baking soda mixed with water you do not want paste or as thick as pancake mix but nice full of the soda and do not get it on the battery.
SHONDAI08
  • 2005 CHEVROLET CAVALIER
  • 125,000 MILES
What is the best kind of motor oil to use for my car? What about spark plugs what are the best kind, GM? Another question one of my windshield wipers does not work can you take me step by step on how to fix it? It the one on the passenger side the one on the driver side works. Last question when it gets very hot outside my temperature moves up what should I do and what does that mean when I say moves it does not stay on 195 it goes to 200 and maybe even 205 degrees.
  • 52,797 POSTS
5-30 oil.
AC-Delco plugs.
Wiper transmission has failed.
Start with a thermostat.
SHONDAI08
Thank you Roy. Where is the transmission located?
PAUL E 59
Four cylinder automatic 63,000 miles.
Drivers side wiper not working, passenger side working okay. How do I disassemble and repair the problem?
MMPRINCE4000
  • 8,548 POSTS
You will have to remove the plastic cowl to gain access.
Make sure the wiper arm bolts are tight, if so then remove cowl and inspect transmission assembly for broken parts.
BRIGHTEYES_0871
  • 2003 CHEVROLET CAVALIER
Four cylinder front wheel drive automatic.
Hi, the other day I was using my wipers due to the rain. They were both working fine, then out of the blue the one on the passenger side stopped working. What could this be?
Tuesday, December 27th, 2016 AT 6:13 PM (Merged)
MMPRINCE4000
  • 8,548 POSTS
The wiper is bolted to a splined gear. The bolt may have come off, or the splines are stripped.
Remove bolt and see if wiper has any play or comes off easily.
The only other possibility is the wiper transmission under the plastic cowl near the windshield.
PBONDO
  • 2001 CHEVROLET CAVALIER
  • 4 CYL
  • 75,000 MILES
Four cylinder two wheel drive automatic 75,000 miles.
The headlights and windshield wipers do not work. Checked the ground pack and cleaned them contact points. The daytime running lamps work. The headlamp bulbs are both good. The windshield washer pump works. Please help.
TANYA777
  • 4 CYL
  • 63,000 MILES
Four cylinder two wheel drive automatic 63,000 miles.
My passenger wiper has stop working, but the driver one does. What should I do or what might be the problem?
