Traction control light on
SATURNTECH9
  • 30,869 POSTS
Iam just saying to take it somewhere that can read traction control module codes.
Saturday, June 20th, 2020 AT 12:23 PM (Merged)
CAVALIER28
Im just worried that they wont find anything wrong and im back to square one and out money
SATURNTECH9
  • 30,869 POSTS
Heres is the clue there is something wrong you said it shifts hard and then you cycle the key and it shifts normal. When it shifts hard its in default mode to help protect the transmission when you cycle the key it resets the code and takes it out of default mode that helps protect the transmission. Something I have seen cause hard shifts like that on those gm cars is a bad inlet air temp sensor connectors. What happens is the copper wires inside the insulation breaks causing the the transmission to shift hard in default mode.
Saturday, June 20th, 2020 AT 12:24 PM (Merged)
