Trac Off warning light on!
112,000 MILES • 4 CYL • FWD • AUTOMATIC
MANNING79
I was driving down the road when my Trac off warning light came on, and I don't know why it came on. Any answers to this question would be greatly appreciated!
Jan 6, 2008 at 11:16 AM
BMRFIXIT
  • 19,053 POSTS
[quote:7309e2a461="Manning79"]Other Category problem
2001 Chevy Cavalier 4 cyl Front Wheel Drive Automatic 112000 miles
I was driving down the road when my Trac off warning light came on, and I don't know why it came on. Any answers to this question would be greatly appreciated![/quote:7309e2a461]
did ABS light come on two or check engine light
you can scan the car to pin point the reason
because it will range from a fuse to a sensor
Dec 16, 2016 at 8:41 AM
TRX680
about two months ago while driving the "trac off" light came on and the transmission shifted really hard after winding out the gears.
The next day the problem was gone. I changed the trans fluid and filter.
It started again today. The "transmission " light came on and shifts hard! The check engine light has always been on since I owned the car because of emissions issue. so I am not sure if there are additional codes to be read with this issue.
Any ideas? Maybe a sensor going bad?
Jun 20, 2020 at 5:29 AM (Merged)
HMAC300
  • 48,601 POSTS
It sounds like you have an input speed sensor that it not working right. We just had one in the shop with the same problem.
TRX680
That was easy! thanks everything working good again I love this site.
HMAC300
  • 48,601 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers
HMENTZER
2001 chevy cavalier. trac light sometimes comes on and shifting becomes very jerky. then when restarting vehicle those symptoms go away.. the last time this happened the car started shifting very jerky.
WRENCHTECH
  • 20,760 POSTS
You will need a professional scan tool capable of accessing the codes in the ABS module and use therm for a starting point.
ETRINIE
I recently replaced my pcm in my 01 cavalier because it stalled on the express way and the trac off light came on. I finally got the relearn procedure for the theft system so the car is now starting but when i put it into drive it immedietly dies. I can restart it but once it goes into drive it dies. The car will drive in reverse but not forward gears any suggestions will be great.
Thnx
Eric
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure first. then clean throttle plate with choke cleaner on both sides.
ETRINIE
Thanks I will try that. I did get a code of P0113 which is the iat sensor but that was it. Is there anything else I should do with the pcm I got this one from a junk yard.
HMAC300
  • 48,601 POSTS
normally these have to be reprpogrammed to the car because theya are vin specific, but try it and see what happens.
ETRINIE
if I have to get it reprogrammed then do I take to my nearest dealer and if so about what is the cost for that?
TRACYB
My trac off light is coming on. What does that light mean? My car is wanting to overheat really quickly.
  • 110,248 POSTS
I don't think the two are related. Check to make sure the coolant level is full. Make sure the cooling fans are working. If they are, replace the t-stat and flush the cooling system.
As far as the trac light, you need to have the computer scanned to identify where the issue is. Most parts stores will do it for free.
HMAC300
  • 48,601 POSTS
do the things i suggested first as anyo fthose could set that code also if there is an air lek between air filter and throttle body it may set the same code. if a dealer has to do it i wold imagine at least $100 possibly more. just call them up and ask. if you still have the old computer try that as it probably wasn't that to begin with. that is why you need to scan for codes and check fule pressure first before any repairs are made. you have to find out what the problem is an dyou can't guess work by doing this or that it just ends up costing you more money and the car runs like crap anyhow.
ETRINIE
Thank You I will try those few things first.
CHERYL5050
I just purchased a 2001 cavalier ls with 103k miles on it it is still under the lemon law in Massachusetts.the first day the check engine light went on took it to be fixed they said when they replaced the o2 sensor the purge or surge sensor went so they fixed that now the next day the check engine light, the trac off light and the abs lights are all on…how can I be sure they are actually fixing the problems and not just replacing sensors..
CARADIODOC
  • 34,413 POSTS
"Just replacing sensors" is a big waste of their time and money unless it fixes the problem. You would know that when you drive away from the dealership and the warning lights are off and everything is working properly.
For the new problems there are going to be diagnostic fault codes stored in the Engine and Anti-lock Brake Computers. Without knowing what the first engine code was, there's no way to know if you have the same problem or a new one. If it's the same code as before, if a sensor is referenced in that code, it is only the cause of it about half of the time. The other half there could be wiring problems related to it. Typically they will just replace the part to get the car back to you faster, and they'll hope that takes care of it. When it doesn't, you have to make a return trip and they have to look further. Also, it isn't that uncommon to get a defective new part. They don't have any control over that except to replace it again.
For the ABS light, by far the most common problem is minor play in a front wheel bearing. GM has had a lot of trouble with them for many years. The play that develops is completely normal but in this case the wheel speed sensors develop a pretty wimpy signal to begin with, and with the little play in the bearing, it reduces even further the strength of that signal. When the signal gets weak enough that the computer can't read it, it sets a fault code, turns the system off, and turns the warning light on to tell you. You can further verify that by watching the live data display on a scanner during a test drive. You'll see one of the front wheel speeds drop to 0 mph while the other three read properly.
It's real important to understand with this type of problem that most of the time once a signal is lost and a fault code is set, many of the other self tests are halted because they need that missing signal for comparison. If you have the problem repaired fairly soon, that's usually the end of it, but if you put it off for weeks or months, a second problem, (typically the other front wheel bearing), will develop the same problem but it won't be detected by the self trests, and there won't be any fault code related to that second problem.
This is where it gets real frustrating for owners and mechanics. When you finally take the car in for a diagnosis, all the mechanic has to go on is the one fault code, so he gives you a repair estimate for the one wheel bearing. It's not until he goes on the test-drive that the other self-tests resume and the second problem is detected. The warning light turns back on and he has to start all over with the diagnosis and tell you more parts are needed. My reason for telling you this is to avoid that frustration in the future. These wheel bearings can develop problems in as little as 15,000 miles but it's more common to need new ones around every 50,000 miles. Those old bearings will work fine on a similar car without anti-lock brakes.
The Traction Control system is an add-on feature to the anti-lock brake system, so even though that warning light is on, it's unlikely there is a second problem in that system. Fix the ABS and the traction control system will work again.
We know that your state has some really strange rules related to lemon laws, but that doesn't apply to your car. You likely have some type of warranty, usually 30 days, included by the dealer, and most commonly that only covers half the cost of repairs. Basically you pay the actual cost of repairs which is half of their bill, (that helps you out), and the dealer doesn't lose any money but they don't make any profit either. They DO lose when your repair ties up the mechanic and equipment which can't be used for another customer.
In most states the lemon laws state you can request a refund if your car is in for the same repair three times while it's under the manufacturer's base warranty, usually 12 months, or it's out of service for a certain number of days. A lot of people think they'll get all of their money back, but they will deduct the depreciation due to the age and mileage and refund the value of the car after that. It would be the same as if you had rented that car for the length of time you owned it. The laws in your state include provisions for crushing cars that aren't repaired within their guidelines. That doesn't benefit anyone, but our politicians know what's best for us.
You may have some type of lemon law for used cars but in most states they only involve new cars. There's usually limitations too for real high warranty periods. If a new car has a 100,000 mile power train warranty and the same thirty-dollar sensor fails three times, 30,000 miles apart, there's no chance they're going to call that a lemon.
KEVIN GUIDEN
got a 2001 chevy cavalier light came on and said trac off. what does that mean.
CARADIODOC
  • 34,413 POSTS
The traction control system is disabled. Usually the anti-lock brake light will turn on too because the traction control makes use of the existing anti-lock system. A problem in the anti-lock system means the traction control won't work properly so both are turned off together.
caradiodoc
DMXX1173
When driving the trac off light comes on then the car shifts really hard when starting out or puling away from a stop sign. What could be causing this problem?
Jun 20, 2020 at 5:30 AM (Merged)
RHALL77
  • 3,361 POSTS
have the vehicle scanned for trouble codes and get back to me with what you find and Ill see what I can do to help
KNPINOY2567
aBS light, and trac off light all on before car suddenly turns off
  • 110,248 POSTS
Interesting. The two components work together, but shouldn't shut the engine off. Have you had the computer scanned?
AMYP0217
car acted like had loose connection with battery had trouble getting it started
  • 75,988 POSTS
Did it attempt to crank over and will not start or just won't crank over at all/nothing when you hit the key to cranking position?
AMYP0217
attempt to crank over with few attempts and it crank
  • 75,988 POSTS
Have the computer scanned for code/s if any present comeback with it-
PROAUTOTECH
  • 288 POSTS
could be two unrelated problems. Make sure you didn't turn off the traction control, it's near or on the blinker switch, usually at the end on that car I think. See if that turns off your light. If it does, I think the hesitation may be something else we'll have to investigate. If that doesn't turn it off, there may be something wrong with your transmission or solenoids and you'll have to get it scanned to find out. The car parts stores will scan it for free.
DONIADAMS
the abs,trac off, and wrench light are on.. which is a abs problem and its a rear sensor but inhave replaced both sensore and the harness on the axel and still on.. what eles could it be??
CARADIODOC
  • 34,413 POSTS
Have the diagnostic fault code read and erased.
DONIADAMS
it comes right back on as soon as earsed
CARADIODOC
  • 34,413 POSTS
Couple things to consider. First of all, fault codes never say to replace parts. They only indicate the circuit or system that needs further diagnosis. In your case, replacing the sensor and the wiring harness would probably solve that code 80 percent of the time. You also have to consider a computer problem, or more commonly a corroded connector pin or break in the wires anywhere between the sensor and computer.
The second thing to be aware of is there is one model of scanner that has a mistake in the software and it reads codes and data for the wrong wheel. It seems to me that was on a GM truck but I can't remember for sure.
You can use a scanner to view live data during a test drive. That will allow you to see the wheel speeds the computer is seeing. If they all seem to be correct, suspect a cracked tone ring. That will cause one extra pulse per wheel revolution which will set a code. I can not find much information on ABS for your year and model so you'll have to see what kind of tone ring is used. GM used a lot of speed sensors built onto the backs of the wheel bearings as an assembly. Those give a lot of trouble when a little, normal play develops from wear. The dealer's scrap metal bins are loaded full of them. It is not uncommon to have problems in as little as 15,000 miles. If your car has a normal external tone ring like everyone else uses, you can look at it to see if it is cracked between two teeth.
Another approach is to go right to the ABS Computer, disconnect the plug and measure the sensor's resistance right from there. You'll need the service manual diagram to figure out which two wires to measure across. A typical sensor will have somewhere around 500 to 900 ohms of resistance. If it's higher than that, or you find an open circuit, measure right at the sensor. If it's okay there, you have a break in one of the wires going to the computer.
You can also measure the AC voltage at the connector that is developed when you spin that wheel by hand. The voltage isn't accurate but all you're looking for is something vs. nothing.
KHLOW2008
  • 41,812 POSTS
What are the codes present?
DONIADAMS
c1234 LR sensor open/short
2CP-ARCHIVES
  • 4,540 POSTS
Hello...I have service engine light, ABS light, and TCS light on. Codes read 1227 and 1234. Story timeline: 10 days ago the rear brake line gave out and had it replaced by a local Firestone dealer. A weeklater I then changed the brakes all around. New pads and rotors in front (rotors cleaned prior to install), new brake hose left front as it didn't allow the caliper to release after braking (brakes smoked excessively, only driven 7 miles total prior to repairing the brake hose; you can visually see both calipers engage and disengage now), new drums in back (shoes showed less than 1/2 wear, no issues getting the drums changed). Here's the problem: when braking hard over 40 mph you feel the ABS kick on and the car tends to lean to the front. It seems as if the problem was in the front left. I took it back to Firestone and they couldn't figure it out on this past Sunday but did replicate the issue. Then yesterday on Wednesday the lights came on. Took it back to Firestone and they couldn't figure it out even with the codes and getting it to replicate again intermittently. Gave the car back to me and told me to take it to a dealer. They inspected the work I did and said it was perfect. Do you have any ideas on what it may be? Thank you for your time I appreciate it!
KHLOW2008
  • 41,812 POSTS
That is the Left rear sensor and the code means it is either shorted to batteery voltage or ground or has an open circuit. since you ahve replaced the sensors and it did not work, it means you have a fault with the wiring. You need to test the wiring between the sensor and ABS control module to confirm whether it is an open or shorted circuit.
did you check the hand brake cables?? could be trying to lock up the wheels activating the abs.
what are the codes for the abs????
DPCONST
We have a 2001 Chevy Cavalier Z-24 with 100,000 miles and a 2.4 liter engine. 150hp.
We have installed a new speed control sensor hoping that it would fix the occassional jerking and hard shifting that the car does at about 40mph. The TRAC light is on when this is happening. Unforturnately, the sensor helped for about two weeks and it started happening again.
We also pulled the codes and there are none present.
Any ideas????
Thanks for your help!! :D
Jun 23, 2020 at 4:30 AM (Merged)
2CARPRO JACK
  • 11,533 POSTS
Need to scan it when it is failing to get a code.could be many things. You could test the resistance across the wheel speed sensors to see if any one is different
