This my same question Does the check engine light need to be reset after an oil change or battery removal.
Tuesday, March 2nd, 2010 AT 1:54 PM
JDL
MECHANIC
Hi, thanks for the donation. Any driveability issues? I didn't see an oil life monitor on your vehicle. You need to check for codes. At the least, you need an obd2 code reader that will check generic as well as manufacturer specific codes.
