2003 Chevy Cavalier Headlight on fuse blows
2003 CHEVROLET CAVALIER
111,000 MILES • 4 CYL • 2WD • AUTOMATIC
ARTPEREZ2
  • 5 POSTS
FixYa:
We understand that your problem is:
I recently installed an aftermarket signal switch assembly which included the cruise control and headlights, recently it started blowing the (ext lamp) fuse when I switch on the headlights from the switch. The daytime running lamps however work just fine. Could it be the switch that is shorting out..
Aug 14, 2010 at 1:00 PM
MMPRINCE4000
  • 8,548 POSTS
If the fuse blows instantly, then there is a short to ground, 12V power is shorting to ground.
If it takes a few munites, then the circuit is overloading, exceeding the amperage of the fuse.
I would recheck all wiring you installed, to start with.
Aug 15, 2010 at 1:48 AM
