Headlight fuse
CAF385
  • 2001 CHEVROLET CAVALIER
Hello I have a 2001 cavalier and recently the left side headlamp fuse has been constantly blowing. I also noticed ever since it started blowing the drl lights come on and off every so often. What could be the cause of this? Any advice would be greatly appreciated. Thanks
Sunday, April 28th, 2013 AT 6:10 PM
CARADIODOC
  • 33,916 POSTS
A simple trick to finding a short is to replace the blown fuse with a pair of spade terminals, then use small jumper wires to connect them to a 12 volt light bulb. A brake light bulb works well. When the circuit is live and the short is present, the bulb will be full brightness and hot so be sure it's not laying on the carpet or against a plastic door panel. Now you can unplug electrical connectors and move things around to see what makes the short go away. When it does, the bulb will get dim or go out.
Sunday, April 28th, 2013 AT 6:30 PM
