2002 Chevy Cavalier I need help
PEREZMIG
  • 2002 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 98,000 MILES
Every morning I have to jump my car because it wont start. I have changed the battery and cleaned all of the grounds I don't know what is causes it. I have even taken out my sound system thinking that was it, I took all the wires out that was connected to my sound system, but it still did the same thing every morning.
Tuesday, November 17th, 2009 AT 10:32 AM
JDL
  • 16,098 POSTS
Welcome to the forum, did you have the charging system checked? The battery has a full charge, around 12.6 volts, across battery posts. Can you check for battery drain? It is best to check amp draw, usually well less than 1/2 amp. That spec may be different for different makes and models?
Tuesday, November 17th, 2009 AT 11:05 AM
