2002 Chevy Cavalier
ANGELOM
  • 2002 CHEVROLET CAVALIER
Interior problem
2002 Chevy Cavalier 4 cyl Two Wheel Drive
How do you replace the head light swith. My headlight went out and whne I pull it in a little they come back on, also the High beams will not stay on unless I hold the lver back
Friday, October 9th, 2009 AT 8:11 PM
RACEFAN966
  • 5,029 POSTS
Well it isn't as difficult as you would think.
1) Remove steering wheel
2) Remove the cover around the column
3) Remove the screws that hold the switch in and remove the switch.
To remove the steering wheel you must disable the air bags here is how to do that.
1) turn wheel straight ahead. Turn off key and remove key.
2) Remove the fuse access panel and remove the SIR fuse (15 amp).
3) Remove the connector position assurance clip and disconnect the two pin yellow connector from the drivers side air bag (pic included below). When done replacing switch put it all back together in reverse order.
https://www.2carpros.com/forum/automotive_pictures/249564_Graphic_140.jpg
Saturday, October 10th, 2009 AT 9:12 AM
