2002 Chevrolet Cavalier Running Hot
MPARS
I have a 2002 Cavalier that keeps running hot . If I take out thermostate its fine. I've replaced thermos, tried 4 just in case could be faulty ones, new water pump, new radiator, replaced motor, nothing seems to be working, Seems no mechanic at garage can see whats causing it since everything been replaced new. IS there something minor i should know about.
Mar 24, 2007 at 1:55 AM
CHEVY22
  • 1,375 POSTS
is the cooling fan coming on at operating temp
jim
Mar 26, 2007 at 12:51 PM
MPARS
yes, the fan is running good. This is a mystery
Mar 26, 2007 at 1:02 PM
YWOODY
Check to see if any on the radiator hoses are extremely soft and spongee. When the hoses that are in this condition they can collapse when they get hot and keep the coolant from circulating. It is more common than people think. The water pump is working fine but the soft hose will close from the pump's suchion from the radiator. Also, surely the mechanic bled all the air out of the cooling system. otherwise there could be a small air pocket where the temp sensor is at and it won't work properly.
Mar 31, 2007 at 6:38 AM
Suggested Repair
Inspect radiator hoses for soft, spongy sections that can collapse when hot and restrict coolant flow. Also confirm the cooling system was fully bled so an air pocket is not affecting the temperature sensor.
Conversation Summary
A 2002 Chevrolet Cavalier overheats unless the thermostat is removed. The owner has replaced multiple thermostats, the water pump, radiator, and engine, and the cooling fan operates normally. An expert suggested checking for collapsing soft radiator hoses and ensuring all air was bled from the cooling system.
