2002 Chevy Cavalier Running Hot
GMC
JJOERG
I have a 2002 Chevy Cavelier with 65,000 miles. Recently the temperature gauge has been creeping up, but hasn't reached the red zone. On cold days it runs slightly above average and on hot days it runs a full quarter of the temp gauge higher. Also, my a/c blows cold air when the car is in motion but becomes very warm when I am sitting at a stop light. What is going on?
May 23, 2006 at 6:57 AM
LOSONE
  • 1,616 POSTS
1st that engine (2.2) is nortorious for running hot and blowing a head gasket or cracking a head. If it has overheated one time you have a problem. Have it checked by a mechanic before you have serious damge.
The A/C could be related to the overheating but you may be low on refrigerant.
May 23, 2006 at 7:03 AM
Suggested Repair
Have a mechanic inspect the cooling system and check for a blown head gasket or cracked head before further damage occurs. The weak A/C at stops may be related to overheating or low refrigerant.
Conversation Summary
The owner of a 2002 Chevy Cavalier with 65,000 miles reports the temperature gauge running higher than normal, especially on hot days, without reaching the red zone. The A/C blows cold while moving but becomes warm at stops. The expert says the 2.2 engine is prone to running hot and can blow a head gasket or crack a head, so it should be checked by a mechanic before serious damage. The A/C issue may be related to overheating or low refrigerant.
