1994 Chevy Cavalier Dies After Running
It is atleast worth a try, and a whole lot less money and trouble than changing a fuel pump and finding out it is not the problem.
It looks like your fuel pump is in your fuel tank, and requires tank access to replace. Your fuel filter is located under the rear of the car, reward of the fuel tank.
Are you sure it is starving for fuel, and not overheating?
Suggested Repair
Try a new fuel cap first so the tank can vent; a sealed tank can build pressure and starve fuel after about 20 minutes. Confirm it is fuel starvation rather than overheating before replacing the in-tank pump. The filter is under the rear of the car, behind the tank.
Conversation Summary
The owner of a 1994 Chevy Cavalier says it runs about 20 minutes, then slows and dies as if it is not getting fuel, and asks whether the fuel pump is bad and how to replace it. A constant whine gets louder when the power windows or turn signals are used. The expert says a bad pump is usually bad all the time, so a fuel cap that is not venting the tank is more likely and cheaper to try. The pump is in the tank and the filter is under the rear behind the tank; the expert also asks whether the car is overheating instead of starving for fuel.
