2001 Chevy Cavalier Violent Shaking at high speeds
CAVEYGUY01
MEMBER
2001 CHEVROLET CAVALIER
4 CYL
FWD
AUTOMATIC
99,000 MILES
When my car reaches speeds of about 50, I can feel it start to drag itself along like its going to stall. But at about 110 to 120 the car really starts to shake uncontrollable like its going to fall apart and it gets worse the faster I go. I'm afraid of taking my car over the highway anymore, in the case that it might cause me to have an accident.
SPONSORED LINKS
Tuesday, October 21st, 2008 AT 8:35 AM
MMPRINCE4000
MECHANIC
First take it to an alignment shop, have the tires balanced and the front suspension components checked (ball joints, tie rods, struts, bearings, control arm bushings).
Wednesday, October 22nd, 2008 AT 9:01 AM
CAVEYGUY01
MEMBER
I kinda figured I needed an alignment but, would those other things cause that much of a problem and how much would you think it would cost on such a low budget.
SPONSORED LINKS
Wednesday, October 22nd, 2008 AT 6:58 PM
MMPRINCE4000
MECHANIC
I cannot estimate cost until the problem is isolated. Violent shaking would indicate possible alignment problem, but could also be a suspension component as I mentioned.
Continued shaking will eventually cause a component failure and you do not want a critical component failure at speed (ball joint for example).
Thursday, October 23rd, 2008 AT 5:43 AM
CAVEYGUY01
MEMBER
I see. I'll try to get the problem fixed as soon as possible, before any major damages arise!
