1999 Chevy Cavalier When I turn on my A/C my check engine l
BRINTI
  • 1999 CHEVROLET CAVALIER
  • 4 CYL
  • 166,000 MILES
A year back my check engine light went on, the engine would run rough when I used the a/c, and when I let my sister borrow it and it was left on my car wouldn't start until I turned it off. Like a good little car owner I ran my vehical to the mechanic. I told him my car acted up when I had the a/c on, he said it was a coincedence. Once he got it into the shop he fixed the major problem and told me that in fact something in my a/c system was failing. Unfortunalty it cost over $700 dollars to fix and I forgot exactly what he said it was. I was wondering what it could possibly be and if I could fix, at least, most of it myself?
Tuesday, June 1st, 2010 AT 2:30 AM
HMAC300
  • 48,601 POSTS
It was probably a compressor/ evaporator or condensor. No you couldn't fix it yourself because you need to evac uate the system and recharge it butyou need to recycle the freon as well. Plus you would need to add the proper amount of correct oil in the new part.
Saturday, June 5th, 2010 AT 8:51 PM
