1991 Chevy Cavalier A/C
DWENG6
  • 1991 CHEVROLET CAVALIER
  • 6 CYL
  • 10,700 MILES
Where do we put the freon in which port the blue or red?
Thursday, April 8th, 2010 AT 6:59 AM
CARADIODOC
  • 33,916 POSTS
Blue hose, engine and compressor running, leave can upright so only vapor goes in. Liquid will damage the compressor. Be sure to use the correct refrigerant. R-12 and R-134 are not compatible. If the can doesn't become empty in a minute or two, place it in a container of hot water, but always keep it upright. If the system was totally empty or was opened to outside air, it must be pumped into a vacuum for a half hour to remove any moisture from condensing humidity before adding refrigerant. Overcharging the system is more damaging than undercharging it
Wear safety glasses and a safety shield. Contact with refrigerant can freeze eyeballs and cause frost bite.
Caradiodoc
Thursday, April 8th, 2010 AT 9:00 AM
