1999 Chevy Cavalier Ignition? Crank Sensor?
1999 CHEVROLET CAVALIER
98,000 MILES • 4 CYL • 2WD • AUTOMATIC
AMANDAP9934
So, I replaced my coil pack and spark plugs yesterday because my car is having issues when im idling and it will have trouble taking off or sometimes just cut off altogether. The check engine light has not come on and i was told it had something to do with the spark. So, I replaced both of the coils yesterday and the plugs and the car is still having issues. I can't hook it up to the diagnostic test and get a reading since the enginne light is not lit. I don't want to pay alot of money and get the dealer to look at it if i don't have to because im thinking that it is either the ignition switch or the crank sensor...Am i way off or do i need to spend the money for a diagnostic test at the dealer and then just fix it from there? I am trying all avenues as money is tight at the moment. Thank you so much for your time!
Aug 19, 2010 at 1:40 AM
MMPRINCE4000
  • 8,548 POSTS
Take ignition module off and have it tested at most autoparts stores for free.
Aug 19, 2010 at 1:52 AM
WRENCHTECH
  • 20,761 POSTS
The check engine light does not have to be on at the time. The system stores codes in memory. If you live near an AutoZone in any state other than CA, they will read them for free for you.
Aug 19, 2010 at 1:58 AM
