1998 Chevy Cavalier runs good until AC is turned on
JENNIFER588
  • 1998 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 170,000 MILES
The car runs good until I try to use the ac. Then the car struggles to go. It has trouble changing gears and it feels like it jumps back and forth when moving. If I stop at a light while the ac is on or park the car it tries to die. If I turn the ac off it runs just fine.
i had someone look at it a week ago and he changed the fuel filter but it didnt fix the problem. Also my gas mileage is 100 miles to a tank less than what I was getting. Please help!
Tuesday, May 18th, 2010 AT 11:21 AM
MMPRINCE4000
  • 8,548 POSTS
Remove and inspect IAC (idle air control valve). When AC is commanded, it should increase idle speed to accomodate increased load.
It is also possible the AC clutch or compressor is bad.
Wednesday, May 19th, 2010 AT 7:56 AM
