1998 Chevy Cavalier brake lights
JOSIAHBELLE
  • 1998 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 125,000 MILES
My brake lights are not working, I have checked fuses, changed bulbs, and the switch at the pedal, what else might be causing this problem
Saturday, January 9th, 2010 AT 9:15 AM
JDL
  • 16,098 POSTS
Welcome to the forum, does the high-mount brake lite work? If it doesn't, I'd have to check feed to and from the brake switch. The orange wire carries voltage to the brake switch. The white wire goes hot when you step on the brake and carries voltage to the highmount brake lite and to the multifunction switch.
Saturday, January 9th, 2010 AT 9:31 AM
