Ok, so today my brake lights and blinkers stopped working. When I turn my blinker it doesn't even click or make a noise. I had the fuse checked and it isn't blown,
what else could be wrong?
Friday, January 23rd, 2009 AT 5:43 PM
MMPRINCE4000
MECHANIC
Check the front and rear bulbs, if OK, then check brake switch on brake pedal arm.
Also check the flasher unit (small cannister under dash) it controls the turn signals.
But more than likely you have a bad bulb(s). If you have a multimeter check bulbs for continuity, use Ohm setting.
