I didn't see the reason to replacing the coolant sensor
you have codes that they are pointing you in the direction off the problem
you need to check cam sensor and O2 sensor and also check for a vacuum leak
check map and or mass air flow sensor
SPONSORED LINKS
Friday, April 25th, 2008 AT 6:41 AM
