My 1989 Chevy Cavalier has the 2.0 L 4 cylinder engine with 90 K miles on it. AT, FWD, I have replaced the Coolant Temperature Sensor, O2 Sensor and Throttle Position Sensor and now it won't idle. It stalls unless I hold the gas peddle down some. Does it have to be trained to idle again? If so, what is the procedure? It seems like it is loading up at low RPMs and has to be revved up to clear it out.
Thanks,
Kent
SPONSORED LINKS
Thursday, July 12th, 2007 AT 10:12 AM
