Engine Performance problem
1997 Chevy Cavalier 4 cyl Front Wheel Drive 206501 miles
should've told u the catalytic converter has been replaced it's new, but not done right. Welds not done right
Sunday, September 5th, 2010 AT 5:25 PM
BLUELIGHTNIN6
MECHANIC
As long as it's on and not clogged or leaking (meaning welds are solid enough to not leak) than it should be good. You can test oxygen sensors but o2 sensors are maintenance parts anyway meaning they actually have a set mileage to be replaced, usually every 80 k miles.
SPONSORED LINKS
Sunday, September 5th, 2010 AT 5:28 PM
HALLCHERYL
MEMBER
Thank u. The weld is not right. So that could be the problem
