O2 sensor, I think.
FTUCKERMAN
  • CHEVROLET CAVALIER
I've got a 2001 Chevy Cavalier, 40,000 miles, 4 cyl. The P0141 code keeps coming on.I changed the O2 sensor on the exhaust manifold, but the check engine light still comes on. Where should I go next?
Thanks
Sunday, May 20th, 2007 AT 8:09 PM
E40WATER12
  • 522 POSTS
Youre engine P0141 code = means EVAP incorrect purge flow, What youre gonna have do is either inspect the charcoal canister filter box near the right front bumper area, If you are not experinced with this I would recommend taking it into the shop, If charcoal canister filter box is damaged or vacuum lines are kinked or broken, Also youre gas cap isnt tighten it will trigger youre check engine light.
Monday, May 21st, 2007 AT 9:18 PM
