1997 Chevy Cavalier 4 cyl Front Wheel Drive Manual 0
I recently replaced my engine in my car, my old engine had 170,000+ miles. My clutch was getting a little worn as well so when I had the engine out I also replaced the clutch with a ClutchMasters FX100 clutch. Now the engine is back in and tranny is bolted on but it will not shift into any gear there is no pressure in the clutch pedal and the lines will not bleed. I have no I dea what to do, I have take the tranny back off and examined the plate, and disc, and everything is correct. Why wont it shift into gear? Hope you can help
SPONSORED LINKS
Thursday, December 20th, 2007 AT 10:54 PM
