1990 Chevy Cavalier 2 door to 4 door engine swap. same engi
90,000 MILES • 4 CYL • FWD • AUTOMATIC
MARKBLU
This should be an easy one. Can I swap the good 2.2L 4cyl engine from my 2 door 90 cavalier into my new 4 door 90 cavalier? I am guessing the engine is exactly the same. Thanks!
Jan 28, 2008 at 11:16 AM
BMRFIXIT
  • 19,053 POSTS
[quote:23d6fbbf34="markblu"]Engine problem
1990 Chevy Cavalier 4 cyl Front Wheel Drive Automatic 90000 miles
This should be an easy one. Can I swap the good 2.2L 4cyl engine from my 2 door 90 cavalier into my new 4 door 90 cavalier? I am guessing the engine is exactly the same. Thanks![/quote:23d6fbbf34]
you go for it same size
same engine
Jan 28, 2008 at 11:18 AM
MARKBLU
Thanks that's what I thought. The cavalier I have now the body is so rusted the car is literally about to fall apart so I bought a dead cavalier same year but 4 door. I got the car from a local junk yard but there is no rust, etc. There are a few parts missing I have to change over like the rear lights and instrument panel. Are there any differences in these things between the two cars?
Jan 28, 2008 at 11:29 AM
BMRFIXIT
  • 19,053 POSTS
[quote:440583c0f0="markblu"]Thanks that's what I thought. The cavalier I have now the body is so rusted the car is literally about to fall apart so I bought a dead cavalier same year but 4 door. I got the car from a local junk yard but there is no rust, etc. There are a few parts missing I have to change over like the rear lights and instrument panel. Are there any differences in these things between the two cars?[/quote:440583c0f0]
good idea.
on the rear im not sure
i think the front is the same
Jan 28, 2008 at 11:47 AM
MARKBLU
[quote:5b9a3d86db="BMRFIXIT"]
good idea.
i think the front is the same[/quote:5b9a3d86db]
Yes I believe I made a good decision. Any ideas on the gauges? The plastic panel is off but the gauges are still there. Will they fit right in place?
Jan 28, 2008 at 11:52 AM
BMRFIXIT
  • 19,053 POSTS
[quote:252caf78e1="markblu"][quote:252caf78e1="BMRFIXIT"]
good idea.
i think the front is the same[/quote:252caf78e1]
Yes I believe I made a good decision. Any ideas on the gauges? The plastic panel is off but the gauges are still there. Will they fit right in place?[/quote:252caf78e1]
I think all the same
sorry not sure its been a while since I worked on one
(I had changed positions )
Jan 28, 2008 at 12:17 PM
