1997 Chevy Cavalier runs fine for about 40-50 miles
WHATSTYLER
1997 Chevy Cavalier Front Wheel Drive Manual 117000 miles
hi, my brother and i bought our cavalier off a lot not to long ago. it drove perfectly all the way home, but the next day we drove it around town for a bit and drove it to bloomington which is about 30 miles away. randomly in busy traffic it starts "sputtering" i guess and it wouldn't give any thrust when we would pump the gas pedal. after sputtering for a few seconds it dies on us. the weird thing is it starts back up immediately after it dies, but after it dies the first time it starts dying like every mile if we have to stop for stop lights and stop signs. if we get to the highway it's usually fine. It's very upsetting because we just got it, and we really need a reliable car to get us to work and back. we have had our fuel filter changed and we brought it to a shop to check our fuel pump, but they said our fuel pump pressure is fine so they couldn't find the problem. it has died like this more than twice, like i said it'll be fine for a good while, like 30-50 miles. then it'll start acting up on us. if anyone has any idea what my problem could be will you let me know? i would appreciate it very much.
thanks
Nov 25, 2009 at 10:45 AM
  • 110,248 POSTS
THis could be the result of many things. When they checked the fuel pressure, the pump may have been fine, but after running it 30 to 50 miles, it may getting weak. Also, has the check engine light ever come on? I've seen crank sensors act this way too.
Nov 26, 2009 at 3:26 PM
WHATSTYLER
hi, thank you very much for replying. ya ive been hearing that it might be the crank sensor, and im hoping it is cuz i heard they are pretty cheap. the check engine light has came on a few times, but its not always on. when we took it to a place to get it hooked up to check the problem the light wasn't on so they didn't find anything.
thanks again!
Nov 26, 2009 at 6:47 PM
  • 110,248 POSTS
That is interesting. Usually when the light comes on, the computer stores the code. Yes, it could be the crank sensor.
Let me know what you find.
Nov 27, 2009 at 9:29 AM
MICOV
I'm havin' the same issue with my 92 cavalier(2.2) but the shop said something about a lean mixture. what might be the culprit???
Nov 29, 2009 at 5:23 PM
  • 110,248 POSTS
When you have a lean mixture, the first thing I check for is a vacuum leak.
Nov 30, 2009 at 11:39 AM
