1997 Chevy Cavalier
MCDOC101
  • 1997 CHEVROLET CAVALIER
Engine Mechanical problem
1997 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
car died when driving go a code p0342 I replaced the cam sensor still will not. On the scanner the timing shows 5.5 deg. And before when it was runing the timing was 15 deg. At idal. I have new fuel pump and iam getting gas and I am getting spark please help me.
Sunday, August 29th, 2010 AT 4:31 PM
  • 109,772 POSTS
Will the engine start at all? Also, the code, P0342
Camshaft Position Sensor Circuit Low Input, have you checkded for damaged wiring or bad connections? Finally, the timing issue, is that 5 degrees BTDC.
Monday, August 30th, 2010 AT 9:07 PM
MCDOC101
I have check wires look good and yes TDC
Saturday, September 4th, 2010 AT 6:35 PM
  • 109,772 POSTS
It should start with that setting. Double check the cam sensor to make sure it is seated properly.
Monday, September 6th, 2010 AT 12:09 AM
MCDOC101
Cam sensor is ok, still nothing
Tuesday, September 7th, 2010 AT 8:24 PM
  • 109,772 POSTS
Follow the cam sensor to the PCM and check voltage output.
Wednesday, September 8th, 2010 AT 10:39 AM
