Welcome to the forum, when the problem occurs, the starter won't crank? Can you tell if there is a load on the starter circuit, when it refuses to crank? Watch the lites, dash lites, headlites, something. The lites should react if load on the starter, dim-- flutter-- go out, something. If the lites stay bright, may be open circuit, purple wire at starter solenoid. Possibilities, faulty wire-- neutral switch-- feed to or from the ignition switch.
The battery does have a full charge and the connections are good?
SPONSORED LINKS
Thursday, November 12th, 2009 AT 1:33 PM
