1996 Chevy Cavalier spark plugs
PFGINGER
  • 1996 CHEVROLET CAVALIER
  • 4 CYL
  • 76,000 MILES
I had sent in a question about the removal of spark plugs for a 1996 cavalier and rceeived a reply stating check your car repair manual - thats a no brainer - but it didn't not address what my real issue is - how can I remove these spark plugs WITHOUT damaging the threads, apparantly the spark plugs have NEVER been changed before
Tuesday, December 1st, 2009 AT 7:56 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Warm engine not all the way to operating temp. Try and loosen about 1/4 turn then spray PB Blaster around plug. If plug is real tight let it soak then use a tighten and loosen switching back and forth. This will break off carbon.
Hope this helps
Thanks for donate
Use anti-seeze compound on new plugs to aid in next removal
Tuesday, December 1st, 2009 AT 10:31 AM
