1996 Chevy Cavalier fuel system
DREAMERSKIES
  • 1996 CHEVROLET CAVALIER
  • 6 CYL
  • FWD
  • 167,000 MILES
I have a 96 camaro, It just started to not want to crank as if its not getting any gas. I can hear the fuel pump come on when I turn the key over, I replaced the fuel filter when I replaced it my car ran for about 10 mins I cut it off and tried to start it again it wouldnt start. I took the new filter off to see if it was clogged with trash. It was not. I placed it back on and it still acts like it doesnt get any gas, what should I check next? Could it be a sensor or something simple?
Saturday, February 7th, 2009 AT 11:53 PM
  • 109,779 POSTS
Hi:
Start by checking fuel pump pressure. It may be running, but not have enough pressure. Many parts stores will lend or rent a gauge. Check out this site for directions:
http://www.2carpros.com/dia/test_fuel_pressure.htm
Let me know what you find.
Sunday, February 15th, 2009 AT 2:59 PM
RHPEARSONII
The one person responding to your question said to check fuel pressure and he is right, but don't forget that a vehicle can have all the pressure in the world but if it don't have enough volume then the vehicle will never run right. Have you checked your ignition system? Many problems seem like they are fuel problems when in fact many times there is something wrong with the ignition system. Have you checked your spark. A spark should jump at least a quarter of an inch on a spark tester, if not the spark is weak. I know at Auto Zone they have adjustable spark tester where you can make the gap shorter or longer to see if the spark is strong enough. A weak spark could make it seem as if it is getting to much fuel because it isn't burning the fuel all the way causing your cylinder's to be flooded, hence the fact that you can't start it after running it for ten minutes. Try taking the fuel pump fuse or relay or the injector fuse out and then crank it to burn excess fuel out of the cylinders. After you do this stick the fuse or relay back in and then try to start it. If it starts look for problems possibly in the ignition system. God bless and maybe this will help if you haven't figured it out yet. Don't car problems suck, but it is a way to learn and get better!
Saturday, February 21st, 2009 AT 12:14 PM
