1996 Chevy Cavalier engine swap
LSOLLAMI
  • 1996 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 127,000 MILES
I've been told that 96 2.4L is different than a 97 2.4L
and if so what is the difference and can it be put in with minimal modifications
Saturday, August 16th, 2008 AT 8:38 PM
MMPRINCE4000
  • 8,548 POSTS
I would contact a junk yard and ask if the two years are interchangeable. They have a lot of information on engines that can be used in different years.
Also call an engine rebuilder such as Jasper and ask the tech line for interchangibility between years.
If they are and have the same engine code (T) then you will most likely have to use manifolds and some wiring from '96 engine.
Sunday, August 17th, 2008 AT 8:40 AM
