Have the ignition module tested. When the modules heat up on these cars, it has a tendency to shut the car off. If it does it constantly, then you may have a fuel pump issue. Since there is no pintle valve on the car to check pressure at the time it dies, shut the car off and turn the key to the on position and listen to see if the pump kicks back on.
Saturday, October 10th, 2020 AT 12:21 PM
(Merged)
