1995 Chevy Cavalier
RACER31
  • 1995 CHEVROLET CAVALIER
Electrical problem
1995 Chevy Cavalier 4 cyl Front Wheel Drive Manual
we have power going into the coil pack but we are getting no spark coming out
Friday, May 2nd, 2008 AT 9:40 PM
BMRFIXIT
  • 19,053 POSTS
Check crank sensor
80o-1200 ohms
Sunday, May 4th, 2008 AT 7:01 AM
RACER31
  • 6 POSTS
We put a new crank sensor in and still no spark
Sunday, May 4th, 2008 AT 4:01 PM
MASTERTECHTIM
  • 4,749 POSTS
99 percent of the time no spark on these engines is caused by a faulty crank sensor or bad ignition module. If you have a scan tool you can read if it has cranking rpms, if not you have to guess and I would give my educated guess at the ignition module.
Sunday, May 4th, 2008 AT 4:06 PM
BMRFIXIT
  • 19,053 POSTS
If u r sure that crank sensor is good and not defective
I would move on to checking the spark module
check wiring
and coil s
Sunday, May 4th, 2008 AT 4:11 PM
RACER31
  • 6 POSTS
New crank sensor tried 3 different computers put in a different wiring harness and have tried a couple different coils still no spark
Monday, May 5th, 2008 AT 8:31 PM
BMRFIXIT
  • 19,053 POSTS
The spark control module (ignition module )
check and or replace it
Monday, May 5th, 2008 AT 8:51 PM
RACER31
  • 6 POSTS
We have no injector pulse could that cause a problem or is this something entirely different?
Tuesday, May 6th, 2008 AT 7:58 PM
BMRFIXIT
  • 19,053 POSTS
Do you have spark
Tuesday, May 6th, 2008 AT 8:50 PM
RACER31
  • 6 POSTS
How can you run 4 injector wires off of 1 wire
Sunday, May 11th, 2008 AT 8:03 PM
RACER31
  • 6 POSTS
We now have spark and the car will start. The car will not stay running now. It runs for 2 seconds and then shuts off. I was told it has something to do with the anti-theft system in the computer.
Sunday, May 11th, 2008 AT 8:05 PM
BMRFIXIT
  • 19,053 POSTS
Do you have a security light on
You should scan for codes too
Monday, May 12th, 2008 AT 7:36 PM
