Thanks!!
1993 Chevy Cavalier Defroster Not Working
Thanks!!
Suggested Repair
Bleed the cooling system to remove an air pocket in the heater core, and confirm both heater hoses at the firewall become hot. Hose direction should not matter. Because the airflow mode stays stuck at the top vents, also check that the blend and mode doors operate properly.
Conversation Summary
After replacing radiator hoses on a 1993 Chevy Cavalier, the owner lost defroster function and wondered whether the two firewall heater hoses were reversed. The expert said hose direction should not matter and suspected an air bubble in the heater core, recommending a coolant bleed and a check of whether both heater hoses get hot. The owner then reported that the HVAC mode controls were stuck, with air continuing from the top vents. The expert advised checking blend-door operation in the air ducts.
