Welcome to the forum. I'd use a gage and check fuel pressure, you can also see if the system will hold pressure. You can do an injector ohms tests, see how the injectors compare. The pressure regulator might allow gas to leak into the intake.
The map sensor should be a three wire connector, ref voltage--ground--signal, also check vacuum source.
SPONSORED LINKS
Sunday, September 13th, 2009 AT 3:04 PM
