1991 Chevy Cavalier shutting down
293,000 MILES • 6 CYL • FWD • MANUAL
STUNTS19
  • 5 POSTS
i just bought a 91 z-24
my car will sit and idle perfectly, and drive, for 10 minutes
then you can hear it struggle a little bit then completely
shut down and not start until it is completely cooled down. it will however try to start every now and then but sounds really bad for a sec then let a backfire out the intake that rumbles my hood
i replaced the coils plugs wires fuel pump and filter i have had many people look at it no one seems to know why
it is reading trouble code 42 ( fuel cutoff relay) what does this mean can u help it would be greatly appreciated thank you
Mar 21, 2008 at 5:16 PM
  • 75,988 POSTS
Is this the 3.1L?
Code 42 relates to the electronic spark timing circuit open or grounded-you sure about this code.
Fuel cut off relay-there's no such thing-you sure you're not talking about the fuel pump relay.
Did you check the fuel pressure and what was the readings when you install the new fuel pump?
Mar 22, 2008 at 12:23 AM
STUNTS19
  • 5 POSTS
yes it is a 3.1 multi-port FI yes i am sure it is code 42 it only says fuel cut off in the book not online.
i looked and looked and i could not find anything for a cut off relay. i did however unhook the fuel pump relay and there was no difference. would it make a difference?
it is also reading code 30 (Idle speed control actuator) can you tell me what this is.
i do not know how to check fuel pressure any tips would be appreciated thank you.
Mar 22, 2008 at 6:29 AM
  • 75,988 POSTS
If the fuel pum/oil pressure sending unit is bad and you remove the fuel pump relay it will stall.
The fuel cut off could be a misprint in the book-Ford product uses this device to shut fuel off in the event of an accident-
Check the fuel pressure-hook up a pressure gauge somewhere within the fuel rail you'll find the pressure test port.
The idle air control valve is on the throttle body take it out and clean it with carb cleaner-
Mar 22, 2008 at 10:17 AM
