1993 Chevy Caprice no start
REBEL300
  • 1993 CHEVROLET CAPRICE
  • V8
  • 146,000 MILES
Car will cut off after it runs for about 10 min it has good fuel pressure but when it cuts off there is no spark, coil icm, and dist have been replaced. Could the pcm be the problem.
Saturday, December 20th, 2008 AT 8:24 PM
BUDDYCRAIGG
  • 2,262 POSTS
You said you replaced the ignition control module.
But you're describing just that.
Did you put the heat transfer grease on it?
Sunday, December 21st, 2008 AT 2:19 AM
REBEL300
  • 6 POSTS
Yes we put grease on it.
Sunday, December 21st, 2008 AT 11:22 AM
BUDDYCRAIGG
  • 2,262 POSTS
There isn't too much to your ignition system.
You replaced the distributor, so it has a new pick up coil
you replaced the ignition module and coil.
The ECM could be bad, but that's pretty rare
i would check to see if the injector is firing the next time it happens.
If it is sparing, then the ECM is getting distributor reference. And you'll know the pick up coil is working and the ignition module is at least part way working.
Sunday, December 21st, 2008 AT 5:57 PM
REBEL300
  • 6 POSTS
Have no problem with the injectors are fuel the problem is when it shuts off you loose all fire from the coil and when it cools for about an hour then the coils start firing again somthing is killing the fire not the fuel
Monday, December 22nd, 2008 AT 4:08 AM
BUDDYCRAIGG
  • 2,262 POSTS
I understand that you do not have spark.
I understand you have fuel pressure.
I want to verify that the ECM knows the engine is turning.
That's why I asked you to see if the injector is spraying.
Monday, December 22nd, 2008 AT 9:52 AM
REBEL300
  • 6 POSTS
Yes we have injector pulse
Tuesday, December 23rd, 2008 AT 9:00 AM
BUDDYCRAIGG
  • 2,262 POSTS
I've asked 3 other moderators to look at this thread.
I just have a gut feeling that it's an ICM problem.
Wednesday, December 24th, 2008 AT 12:01 AM
DOCHAGERTY
  • 9,601 POSTS
If I may offer my humble opinion. I had a General Motors car doing the same thing, I tracked it down to a fuel injector or injectors heating up and shorting out. If the spark goes away it might be related to the PCM seeing a shorted injector and shutting the system down. I hope this is some data you can use.
Wednesday, December 24th, 2008 AT 10:38 AM
Recheck the coil and ICM-Dunno if this has a CPS if it does check it-
Wednesday, December 24th, 2008 AT 1:31 PM
BUDDYCRAIGG
  • 2,262 POSTS
Was the car having this problem all along and that's why you replaced the coil, ignition control module, and the distributor?
Was there ever a change when you replaced any of the parts?
I think I've got a way that we can test the coil.
If you have a remote tachometer (most $5 dollar dwell meters have a tach setting on them)
Connect the tach to the white wire going from the ICM to the coil. Set the meter to the low RPM range.
If you get a reading while cranking the engine, then you know the ECM and the module are working and the coil is bad.
If you don't get a reading then the problem is up stream, possibly the ECM or module.
I think I've got a way to test the module.
When is dies.
Put the electronic SparK Timing into by-pass mode.
Unplug the "set-timing" connector it's a single wire in the wiring harness on the left side of the engine, near the AIR control valve. Tan with a black stripe.
If the car start up, the module is working. (Or at least most of it)
So the problem would have to be upstream, possibly the ECM.
That's all the info I can come up with.
Good luck
Wednesday, December 24th, 2008 AT 11:00 PM
REBEL300
  • 6 POSTS
Yes this car has had same problem before any parts were changed.I have ordered a pcm and going to try that car has a short somewhere the dash lights and speedometer goes crazy when you try to restart after it cuts off. Maybe it will fix the problem.
Friday, December 26th, 2008 AT 1:06 PM
BUDDYCRAIGG
  • 2,262 POSTS
Good luck
let us know how it goes.
Friday, December 26th, 2008 AT 4:29 PM
