Crank no start
NATION69416
the car will crank but wont turn over
Aug 9, 2010 at 9:09 AM
Depending on what engine this has, the issue may vary. If this was a 5.7L then it is fuel injected and we need to check for fuel pressure.
However, if this is any other engine then it will have a carburetor on it, and we simply need to spray starter fluid in the top and see if the engine fires.
If it doesn't then we need to check for spark. Here is a guide that will help with this:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Once we know if this is fuel or spark related then we will have a better idea which direction to go.
However, if you have fuel and spark then we need to check compression and find out if we are low on compression which could be a timing issue or a larger engine issue.
Please run through all this info and let us know if you have fuel, spark, and compression and then we can go from there.
Thanks
Apr 19, 2022 at 8:37 AM
