Window seal strip
PAR4DCOURSE
I have a '97 3.8 w/100k on it. When the previous owner had the passenger side window motor replaced (big surprise) the mechanic left the outside rubber strip between the top of the door and the windw loose. This has been my thorn in an otherwise great car.
I need instructions or a diagram on how to remove the door liner to get at it. It has 5 or so regurlarly spaced clips on the strip but in a year of off and on trying I still can[t get it fastened.
Any and all help appreciated.
Mar 21, 2007 at 6:16 AM
MERLIN2021
  • 17,250 POSTS
usually you remove the window crank or power switch remove screws holding the grab handle and just put a flat screwdriver between the panel and the door and pop the clips out!
Apr 17, 2007 at 2:41 AM
