1991 Chevrolet Camaro Trunk Won't Close
I found a photo of the unit. It looks like the motor is under the cover by the latch itself. The relay is mounted into the harness at the motor. Not sure where the fuse is located, but Im still looking.
I found a photo of the unit. It looks like the motor is under the cover by the latch itself. The relay is mounted into the harness at the motor. Not sure where the fuse is located, but Im still looking.[/quote:a90534b788]
Ok, the fues is called the lid fuse, and is located on the fuse block. You will know if the fuse is bad because it supplies power to the cargo compartment light also. No light, suspect fuse. You got light, suspect motor or relay.
In looking at the diagram, there looks like there is a fuse located in the motor itself.
Suggested Repair
Check the lid fuse on the fuse block first. That fuse also powers the cargo compartment light, so no light points to the fuse. If the light works, inspect the relay in the harness at the trunk motor and the motor under the cover by the latch; the diagram also shows a fuse in the motor itself.
Conversation Summary
A 1991 Chevrolet Camaro owner reported that the motorized trunk release opens the trunk but will not pull it closed. They had been told the fuse, relay, or motor could be at fault and could not find the trunk motor in the manual. An expert said the motor is under the cover by the latch, with the relay in the harness at the motor. The lid fuse is on the fuse block and also feeds the cargo light; no light suggests a bad fuse, while a working light points to the motor or relay. A fuse may also be located in the motor.
