1998 Chevrolet Camaro Stalls After Driving
MONIKAMCKAY
Hi my name is Monika, i have a Chevy Camaro 98 155,000 miles 3.8 Litre, I was just wondering if anyone could Pleaaase help me locate the Crank and Map sensors so i can replace them in detail ? and if its not too much i was thinking of putting power windows on this summer seing how its all manual so i was wondering if someone can tell me if that would wreck the car and what the right way to do it would be, i bought the Mitchelle repair book so if that helps maybe you can point out where on the book that would show me how .
Thank you SO Much :) !
Feb 27, 2007 at 5:25 PM
SERVICE WRITER
  • 9,123 POSTS
Look in the engine performance section, ignition system. I don't have the book but logically that is where I would expect it to be.
https://images.2carpros.com/forum/automotive_pictures/30961_camcam_1.jpg
The right front wheel has to come off and the harmonic balancer as well to access the cranshaft position sensor. You'll need a puller for that.
Feb 27, 2007 at 8:10 PM
MONIKAMCKAY
Hi Thank you So much for your Help I really Appreciate it :D! could you tell me where the map Sensor is please ? :oops:
Feb 28, 2007 at 6:40 AM
SERVICE WRITER
  • 9,123 POSTS
right rear of the intake manifold, above the valve cover.
https://images.2carpros.com/forum/automotive_pictures/30961_winkbaby_3.jpg
Feb 28, 2007 at 10:42 AM
MONIKAMCKAY
Hi my name is Monika, i have a Chevy Camaro 98 155,000 miles 3.8 Litre, I was just wondering if anyone could tell me what could possibly be wrong with my car, it'll drive for about 5-8 minutes good then it stall, backfires, and the rev goes down to 0, i took it to a scan test and said i needed to replace the crank and map sensor which i did but it is still doing the same exact thing $730 later Grrrrrrr!!!So if anyone knows whats wrong with it i would REally appreciate the help.
Thank you,
Monika E.
Mar 19, 2007 at 10:03 AM
SERVICE WRITER
  • 9,123 POSTS
HEy Monika,
My guess is they told you the codes, but didn't diagnose it. You need to clear the codes and have a crankshft position sensor variation learn precedure done on it since you replaced the sensor. You need a scanner capable of doing this however.
Mar 19, 2007 at 10:18 AM
Suggested Repair
After replacing the crankshaft position sensor, clear the codes and perform a crankshaft position sensor variation relearn with a scan tool capable of that procedure. The crank sensor is behind the harmonic balancer (right front wheel and balancer must come off; a puller is needed), and the MAP sensor is at the right rear of the intake manifold above the valve cover.
Conversation Summary
The owner of a 1998 Chevrolet Camaro 3.8L asked where the crankshaft position and MAP sensors are and whether power windows could be added. The expert located the crank sensor behind the harmonic balancer and the MAP sensor at the right rear of the intake manifold. After both sensors were replaced, the car still drove a few minutes, then stalled, backfired, and the tach dropped to zero. The expert said the codes were likely read without a full diagnosis and recommended clearing codes and performing a crankshaft position sensor variation relearn with a capable scanner.
