other info, not sure if its related but the safty dinger when you press the door locks with the door open works sometimes and not others.
1998 Chevy Camaro Radio Cuts Out
That is if you want togo this route.
let me no what you come up with
Richard
Thanks for the great help.
Suggested Repair
The intermittent radio was traced to the constant-power feed. Unplug the yellow constant 12-volt radio wire at the fuse box and tap it into a known constant fuse, such as an instrument-panel fuse. If needed, also connect the red switched wire to a key-on fuse and secure a solid metal ground.
Conversation Summary
The owner of a 1998 Chevrolet Camaro said the radio kept cutting in and out after the stock CD player was replaced. Disconnecting the speakers did not stop it, and the radio retained its memory, so speaker grounding and total power loss were unlikely. An expert suspected a wiring short and suggested running new constant and switched power from the fuse box with a solid ground. The owner tapped the yellow constant wire into another fuse, and the radio then worked correctly. An intermittent door-lock chime was mentioned but not diagnosed.
