2000 Chevrolet Camaro No Start
BERNELL DUNCANJR
I BOUGHT THIS CAR IN MARCH, IT HAS 105255 MILES. V6 ENGINE AUTOMATIC, FIRST IT WAS TRYING TO TURN OVER BUT WON'T CATCH. THE FUEL PUMP AND RELAY, FILTER, REPLACED, 3 WEEKS LATER IT WON'T START, TOW IT TO DEALERSHIP, IT WAS AN INGITION RELAY, REPLACED, 1 WEEK LATER IT WON'T START, IT WAS THE COMPLETE INGITION SYSTEM REPLACED TWO NEW KEYS AND KEYLESS ENTRY WAS PURCHASED. ALL AT THE DEALERSHIP. TODAY AFTER 5 DAYS OF GETTING CAR BACK. IT WON'T START AGAIN. DEALERSHIP HAS IT AGAIN. THEY DON'T HAVE A CLUE, NO FAULTS ARE SHOWING UP OR CODES, PLEASE HELP, I'VE SPENT OVER $2500 AND I STILL CAN'T DRIVE CAR. WHEN YOU TURN THE SWITCH AT THE FIRST POINT ALL LIGHTS COME ON AS IF IT;S GOING TO START, SECOND POINT IT HAS NOTHING. GOT IT TO DEALERSHIP, AND IT STARTED FINE, DON'T KNOW WHAT ELSE TO DO, CAR HAS LEFT ME STRANDED MORE THAN I'VE DRIVEN IT.
May 31, 2007 at 9:06 AM
E40WATER12
  • 522 POSTS
Sounds to me a common problem, The anti-theft imoboilizer system sometimes freezes up in the relay, Causes the car to not start, My friends 98 camaro did the same thing, Before, His Camaro had gotten stolen before, In which has caused a great deal of problems. Now he got the imoboilizer replaced, Never had that issue since.
GoodLuck.
Jun 7, 2007 at 9:15 PM
Suggested Repair
Have the anti-theft immobilizer system and its relay checked or replaced. A frozen immobilizer relay can cause an intermittent no-start even when no fault codes are stored.
Conversation Summary
A 2000 Chevrolet Camaro V6 automatic with about 105,000 miles repeatedly fails to start. The fuel pump, relay, filter, ignition relay, complete ignition system, keys, and keyless entry were replaced, but the no-start returned and no codes were found. Lights come on in the first switch position, yet the second position does nothing; the car sometimes starts normally at the dealership. The expert says a common cause is the anti-theft immobilizer freezing in the relay and recommends replacing the immobilizer.
