1999 Camaro 5.7
TMILLSD
P1416 Secondary Air System, P0410,P0412,P0418,P0137,P0157
Diagnosed fuse for AIR PUMP BLOWN. AIR PUMP INTERNALLY LOCKED UP. Needs Air Pump and Fuse.
This is what the mechnanic told me. and would cost over $500.00 to fix. I would like to do this myself and would like to know where the Air Pump is located?
Mar 10, 2007 at 1:51 PM
2CARPRO JACK
  • 11,533 POSTS
I believe it is mounted on the lower drivers side front of the engine. The secondary air codes are probably due to blown "gulp" valves, they keep exhaust from being pushed back into the air pump, which is possibly why yours locked up.The valves are on the lines that come out of the exhaust manifolds.
Mar 11, 2007 at 12:19 AM
