1997 Chevy Camaro Oil leak
STARRMOON
Engine Mechanical problem
1997 Chevy Camaro 6 cyl Two Wheel Drive Automatic
I brought this used car in april and I knew I needed a oil gasket but it was not that bad until the weather changed and not it is leaking very bad i have to put 2 - 3 qts of oil in it evey time i drive it. Is it any thing I could do to save my oil until I am able to get the gasket fix
Dec 7, 2008 at 2:26 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Sorry to say but, not really. Once the oil leaks out and drips onto anything, it will become contaminated with dirt and other particles not visible to the naked eye. If you were to try and reuse the contaminated oil, it could harm major engine components internally. Repair the leak as soon as possible is all you can do.
Dec 7, 2008 at 2:29 PM
