Engine Mechanical problem
1996 Chevy Camaro 6 cyl Two Wheel Drive Manual
Went out to start it it turns over but will not start. I put gas in it, I have tried to jump start it, also charged it.
Thursday, November 26th, 2009 AT 10:03 PM
MICKEY-D
MECHANIC
Have someone crank the engine, and check for spark at the plug wires. If you have spark, try giving it a shot of starting fluid while cranking it over. If it starts, you have a fuel problem. Fuse, fuel pump, relay, or maybe a bad fuel filter. Good luck. Mickey-d
