1996 Chevy Camaro Car will not start
HKATEAM
  • 1996 CHEVROLET CAMARO
Computer problem
1996 Chevy Camaro 6 cyl Two Wheel Drive Automatic
My car will not run unless I keep my scan tool hooked up. I have replaced the computer and problem remains.
Wednesday, February 18th, 2009 AT 6:19 PM
MASTERTECHTIM
  • 4,750 POSTS
The ground for the ecm is broken. Its usually on the thermostat housing or close by. Look for a small brown wire or black wire and lightly tug on it and see if it seperates. It runs with the scanner hooked up because its getting a back feed through the scanner.
Saturday, August 17th, 2019 AT 4:56 PM
HKATEAM
  • 10 POSTS
Thank you, will work on it.
HKATEAM
  • 10 POSTS
All connections seem to be good. I have found out that if I move the brown wire right at the pcm ( the front bank of the pcm) the fuel pump kicks on. (I turned on the ignition key to help me find the bad connection.) I also read in my book (haynes repair manual) that the brown wire is the power to the pcm and the ground is black/white. I am not sure what to do next. Do I need to replace the entire harness?
BTW thank you so much mastertechtim, I feel I am alot close than I was.
MASTERTECHTIM
  • 4,750 POSTS
No. Try adding a ground right to the b lack and white wire and see if it runs
HKATEAM
  • 10 POSTS
YES YES YES it worked. FIrst time in 4 months the car has stayed running for more than 3 minutes.
I drove it up the road a ways and it seems to be running great.
THANK YOU THANK YOU THANK YOU.
MASTERTECHTIM
  • 4,750 POSTS
No. Thank you. Even though we would do this for free, the donations help out alot. Thanks tim
