1995 chevy camaro is backfiring
MOWERMAN
I have a 1995 Chevrolet Camaro with 90,000 original miles. It has a 3.4 v-6. I noticed when I am on the highway and the transmission has shifted to overdrive and I try to accelerate to pass a vehicle I can feel it shuttering. The engine will backfire and then shift out of overdrive. If I manually shift from OD to D it does not do this. I have changed the transmission fluid and filter. About 10,000 miles ago it had new plugs, plug wires and fuel filter put on it. Any idea what might be wrong.
Jun 24, 2007 at 4:21 AM
E40WATER12
  • 522 POSTS
Might want to get youre coil packs tested.
Jun 28, 2007 at 10:03 PM
MOWERMAN
How would I go about testing them, is it something I could do or should I get a dealership to do it.
Jun 30, 2007 at 12:34 PM
E40WATER12
  • 522 POSTS
Testing coil packs, U need digital multi meter, Tester to measure the ohm reading from the sensors current flow.
Jul 2, 2007 at 10:19 PM
