1995 Chevy Camaro Engine
197,000 MILES • 6 CYL • 2WD • AUTOMATIC
TAYLORSVILLE
My camaro started out running hot. I replaced the thermostat,and when I was filling it up with anti freeze,I noticed my freeze plug was leaking. I have yet to replace the plug, however, the car seems to be running very erratic. It will idle fine,but when I put it in gear, it starts to choke down. I can put the gas pedal to the floor, but it will not rev up. I have recently replaced all spark plugs and plug wires and fuel pump and filter. It should be noted that I had to remove the catylitic converter a few months ago.
Any Ideas????
Feb 29, 2008 at 1:20 AM
DAN P
  • 9 POSTS
I would check fuel pressure, it should be above 48 psi ,also i have seen many driveabilty problems caused by low coolant level ,the coolant sensor is designed to be in coolant, NOT hot steam, let us know what you find.
Mar 10, 2008 at 2:43 PM
