1995 Chevy Camaro 95 3.4L Camaro acceleration issues
CANDYAPPLE95CAMARO
  • 1995 CHEVROLET CAMARO
  • 6 CYL
  • 144,200 MILES
My 95 3.4L camaro seems to have trouble accelerating quickly and it seems to lag a little on shifting times. It also topped out around 93-95mph and I would have a higher top speed. My car was recently leaking oil, water, and coolant and needed a new seal. I also changed the serpentine and timing belts aswell. What could my problem possibly be?
Monday, January 26th, 2009 AT 7:40 PM
MASTERTECHTIM
  • 4,750 POSTS
This car doesnt have a timing belt?
Monday, January 26th, 2009 AT 7:45 PM
CANDYAPPLE95CAMARO
  • 6 POSTS
Sorry. Im not sure what the name of the other belt is. They told me that they had to remove the engine to get to it. If that helps at all.
Thursday, January 29th, 2009 AT 9:57 PM
MASTERTECHTIM
  • 4,750 POSTS
Im sorry. This could have a timing belt. Is it a 3.4litre engine and I need to know if the eigth letter of the vin is. If its a x then it has a timing belt and we can go from here to get to the bottom of it.
Friday, January 30th, 2009 AT 11:29 AM
CANDYAPPLE95CAMARO
  • 6 POSTS
Hey my VIN is 2G1FP22S6S2145151
Friday, January 30th, 2009 AT 4:25 PM
MASTERTECHTIM
  • 4,750 POSTS
https://www.2carpros.com/forum/automotive_pictures/139033_no_18.jpg
your engine has a timing chain so i dont think that is your issue. i would be leaning towards low fuel pressure or fuel volume caused by a clogged fuel filter. remove fuel filter and dump the fuel inside into a glass bottle (like snapple) and see what the contents look like. if its dirty and gas doesnt flow out of it real fast when you tip it upside down then its plugged.
Friday, January 30th, 2009 AT 6:03 PM
CANDYAPPLE95CAMARO
  • 6 POSTS
Okay I will check that out and then post up the results, but if it is plugged I should just put a new filter on right?
Monday, February 2nd, 2009 AT 11:53 AM
MASTERTECHTIM
  • 4,750 POSTS
Tuesday, February 3rd, 2009 AT 7:27 AM
